Highlighted posts from Sunday, Jan. 16, 2022
SN95Newsletter
Click here to view on the web
Highlighted posts
January 15, 2022 * 10 posts * 72 views
Wmac said: Then pull the tailpipes, measure outlet of muffler, see your friend at napa for 2 turndowns. Cost 25/30 bucks. If you want to try different mufflers, reuse your flowtubes. (maybe ... Read more >>
January 15, 2022 * 9 posts * 97 views
tinnocker said: I can tell you what I know but if you Google, their is plenty more. The bars are a raised markings on the end of the heads , 1/4''x 1.25 '' approximal. The three bars came out ... Read more >>
January 15, 2022 * 1 post * 12 views
SN95Newsletter said: Click here to view on the web Highlighted posts What goes here? January 14, 2022 * 19 posts * 161 views Exterior and Interior GT40 Heads................ January 14, 2022 * 7 posts ... Read more >>
January 15, 2022 * 12 posts * 151 views
dcm0123 said: Smoke check as mentioned above- problem could be masked by a massive vacuum leak. Disconnect all vacuum lines leading from the engine which you did not replace and plug the ends ... Read more >>
January 15, 2022 * 112 posts * 1,338 views
Jason.Silus said: Drove the mustang to work today, and got gas on the way. Got a call that my brother that I live with tested positive for COVID, so I had to go home. On the way home I started smelling ... Read more >>
January 16, 2022 * 23 posts * 1,089 views
flyboygeo said: Did you use the fox style bellhoising? And not just fox clutch fork. Read more >>
Continue reading...
