Highlighted posts from Sunday, Nov. 07, 2021
SN95Newsletter
Click here to view on the web
Highlighted posts
November 07, 2021 * 61 posts * 403 views
Makoto said: so the idle, yes, but at full trot it should be fine. I removed the passenger pcv, replaced it with a straight pipe, did base idle reset, and now the idle is higher (like 1250-1300rpms) ... Read more >>
November 06, 2021 * 7 posts * 78 views
Flade said: What upper manifold do you have? If it is the 94/95 cobra, you don't do anything. The upper manifold is not plumbed for it. The EGR mounts to the side of the manifold like the ... Read more >>
November 07, 2021 * 5 posts * 54 views
96blak54 said: Cant go wrong with the pi intake! Its the choice for street performance. If you want more n/a power, youll need rpm and the edelbrock uncorks the potential, but dont assume swapping ... Read more >>
November 06, 2021 * 8 posts * 79 views
d.garza18 said: I agree. Mine worked fine, but they don't clip in and being held on with zip ties isn't comfortable for me. I'm relooming the whole harness, and trying to save where I can so oem ... Read more >>
November 07, 2021 * 3 posts * 22 views
Jake-96-gt said: Hi everybody, I have been pocking at my cars wires all day because the car does not start nor crank. When you turn the key to power, all the dash lights light up and all the plugs ... Read more >>
November 06, 2021 * 44 posts * 348 views
07GtS197 said: All of Florida is is touristy unfortuneately. It still is a great place to live. My brother in laws parents are more of a casino type than aquarium type lol. I'm sure they've been ... Read more >>
November 06, 2021 * 1 post * 14 views
Daryl said: I have a '95 SVT Cobra coupe with the Eibach Pro-Plus rear suspension and MM (Maximum Motorsports) adjustable Sport level rear control arms. I have also replaced the upper control ... Read more >>
November 07, 2021 * 1 post * 10 views
SN95Newsletter said: Click here to view on the web Highlighted posts Car is tuned, runs great, at idle it dies when all the electronics are on November 05, 2021 * 49 posts * 300 views 96-04 - 4V Specific ... Read more >>
November 06, 2021 * 13 posts * 174 views
RAU03MACH said: They will make any sn body look good I have a set on my 98 gt There replica but look good these are my favorite Original are hard to find , I do look for them I run into a lot ... Read more >>
Continue reading...
