Highlighted posts from Thursday, Apr. 07, 2022
SN95Newsletter
Click here to view on the web
Highlighted posts
April 06, 2022 * 11 posts * 59 views
joemomma said: There may be a link between cruise and ABS - seems like I had a car (Lincoln) a few years ago that the cruise wouldn't work with the ABS light on. Read more >>
April 06, 2022 * 12 posts * 121 views
SouthernGorilla said: Yeah, I'm definitely expecting mods. My problem is identifying them ahead of time. Like right now, the rear end bottoms out constantly. So I'm reasonably sure it has weak aftermarket ... Read more >>
April 06, 2022 * 11 posts * 127 views
07GtS197 said: I was just curious since I knew of the differences. My 09 P71 has a new intake without the temp sensor boss and it just got me thinking. It's something most people would overlook, ... Read more >>
April 06, 2022 * 5 posts * 32 views
ttocs said: There are no spots on the factory regulator to tap for pressure that I am aware. Depending on the year the schrader valve on the rail is the easiest place. Read more >>
April 06, 2022 * 8 posts * 74 views
ttocs said: I know I am looking forward to drag radials because as it is now a slow roll into 2nd and it starts spinning half way through. Read more >>
April 07, 2022 * 17 posts * 181 views
04RedfireGT said: So I've gotten brake cleaner and sprayed it on all vacuum lines, around the throttle body, and the intake that I could see or hit with the cleaner and it didn't rev higher. Read more >>
April 06, 2022 * 1 post * 10 views
SN95Newsletter said: Click here to view on the web Highlighted posts Exhaust set up help! April 05, 2022 * 27 posts * 342 views Exhausts Identifying PI Intake April 05, 2022 * 8 posts * 78 views 96-04 ... Read more >>
April 06, 2022 * 21 posts * 166 views
SN95_Project said: I'd believe you, but as soon as the one-touch relay is plugged in, the motor goes down on it's own (no switch getting pushed). If it was the motor, I would think pressing the switch ... Read more >>
April 06, 2022 * 26 posts * 353 views
joemomma said: You can get 90 degree boots or insulators for the plug wires to protect them from the heat. Your intake should work on the new heads. Not to burst your bubble, but any GT40/GT40P ... Read more >>
Continue reading...
senior001
