Highlighted posts from Thursday, Jan. 06, 2022
SN95Newsletter
Click here to view on the web
Highlighted posts
January 05, 2022 * 6 posts * 102 views
Notthenow said: Iwarrior is correct, pinion up same amount trans output is down. In steady state they will be that way and ujoints will work best. Normal suspension movement will keep them within ... Read more >>
January 06, 2022 * 11 posts * 121 views
ttocs said: man I was SURE my GPS had screwed up till I finally saw the sign to turn in. Its out in the country a bit. Sweet track though. I hit 132 in the gt500 the first time ever on the ... Read more >>
January 06, 2022 * 1 post * 5 views
SN95Newsletter said: Click here to view on the web Highlighted posts Transmission Crossmember Direction and Proper Pinion Angle January 04, 2022 * 5 posts * 45 views General Tech Highlighted posts ... Read more >>
January 05, 2022 * 84 posts * 923 views
THE FLIGHTLESS KIWI said: Have you checked the emergency(side impact)shut off switch for the fuel pump. If that has a fault, maybe it could be causing all your intermittent problems. This is a resettabe ... Read more >>
January 05, 2022 * 14 posts * 318 views
white95 said: There is an autocross event tentatively scheduled for January 30th & and I'm registered for a two day track event February 26-27. Read more >>
Continue reading...
