Highlighted posts from Thursday, Jan. 13, 2022
SN95Newsletter
Click here to view on the web
Highlighted posts
January 12, 2022 * 18 posts * 103 views
TrickVert said: For anti-theft: Get a junkyard defroster switch, and wire in a relay to the crank circuit (so you'd have to push the defroster switch while turning the key to start the car). You ... Read more >>
January 12, 2022 * 7 posts * 61 views
tvsn95 said: Well that's just fascinating, What little I read they don't appear to have long service life , but for drag cars would be simple to setup, There has been rear mounts done in the ... Read more >>
January 12, 2022 * 5 posts * 65 views
Randall Garner said: If your speedo is not working check the connection at the trans, at the passenger side fire wall where the main is. Also look for a fuse or relay that may be blown. I had this ... Read more >>
January 12, 2022 * 1 post * 8 views
SN95Newsletter said: Click here to view on the web Highlighted posts What goes here? January 11, 2022 * 13 posts * 44 views Exterior and Interior Need help from some knowledgeable individuals!!! We're ... Read more >>
Tune
January 13, 2022 * 8 posts * 130 views
Addermk2 said: Your budget will dictate what direction you should take. $500 - Microsquirt PnP $1000 - Stinger PiMPxS or Goldbox $1500+ Holley Terminator Read more >>
January 12, 2022 * 107 posts * 1,214 views
Jason.Silus said: Hoping to get by with just the one injector, but once I get another problem with one, I think it'd be a good investment to go ahead and replace the whole lot of them. The sending ... Read more >>
Continue reading...
