SN95Newsletter
- Joined
- Mar 31, 2021
- Messages
- 547
- Reaction score
- 0
Click here to view on the web
Highlighted posts
June 03, 2021 * 9 posts * 166 views
TrickVert said: I think you're missing my point. Too large a pump will simply circulate unused fuel through the engine compartment over and over and over again, causing it to absorb heat. Many ... Read more >>
June 02, 2021 * 7 posts * 101 views
ttocs said: yea that sounds like it could be the premium sound amp in the dash at least I would start there. On the drivers side of the console if you peel back where the carpet meets the ... Read more >>
June 02, 2021 * 11 posts * 278 views
Daryl said: Sidebar question: what does H/C/I stand for? I have interest in this thread but don't want to hijack Joemomma's thread. Read more >>
June 02, 2021 * 2 posts * 60 views
skidoo said: Not a lot of information here, can you give more details? When you say you broke the engine in, does that mean it's a complete rebuild? New pistons and machined the crank, bored ... Read more >>
June 02, 2021 * 1 post * 3 views
SN95Newsletter said: Click here to view on the web Highlighted posts Fuel pump requirements June 01, 2021 * 4 posts * 117 views 94-95 5.0 - Specific Battery drain June 02, 2021 * 4 posts * 35 views ... Read more >>
June 03, 2021 * 20 posts * 272 views
Daryl said: If I hadn't, I apologize. If I did, I'm happy to reiterate: When I start the car up (doesn't matter cold start or if I've been running it around town), it seems to struggle to ... Read more >>
June 03, 2021 * 117 posts * 2,362 views
TrickVert said: The OEM pump is 110 LPH. Given the capabilities of a 347, I'd say that's probably not enough. The trouble is, any tuner worth his salt should have seen (and told you) the fuel ... Read more >>
Continue reading...
