Highlighted posts from Thursday, Nov. 18, 2021
SN95Newsletter
Click here to view on the web
Highlighted posts
November 15, 2021 * 7 posts * 65 views
e.phillips1113 said: Any ideas on how to get it to seal? I could always just drill out the hole and tap it up to a larger size I suppose? But that still runs the risk messing with the sealing surface. ... Read more >>
November 14, 2021 * 6 posts * 55 views
94StewFord said: I have the 2.5" X Pipe on it's way, so if I only have to upgrade the Flow Tubes and Mufflers, that would be great it the Tail-Pipes are 2.5" ?? My tailpipes are in excellent original ... Read more >>
November 14, 2021 * 28 posts * 278 views
waynenorcross said: Closed loop is absolutely affected by coolant temperature. I went back to some old threads when I was in the SVT forum and the SCOA forums and 170 degrees keeps popping up. Plus, ... Read more >>
November 17, 2021 * 3 posts * 23 views
Daryl said: My wife has an SUV so it's on the hit list for catalytic converter theft. Couple people we know already are victims. Apparently takes thief's about 5 minutes and they'll do it ... Read more >>
November 15, 2021 * 15 posts * 147 views
ttocs said: this is all good advice. Checking grounds should always be the first part of any electrical diagnosis but to be sure to actually check them. We do not mean look at or even touch ... Read more >>
November 15, 2021 * 3 posts * 38 views
OpalFrostGT said: The "tape" has glue on the topside but not the bottom side. A carpet layer uses a hot iron beneath the twp pieces of carpet. He slides it along the "tape" that has glue on the ... Read more >>
November 17, 2021 * 23 posts * 311 views
Clutch Cargo said: The only reason I am making a comment here is because I had something similar happen. An "out of the blue" dip in RPMs. Took it back to my engine builder and of course they could ... Read more >>
November 16, 2021 * 1 post * 15 views
SN95Newsletter said: Click here to view on the web Highlighted posts ABS Unit Hole Stripped November 15, 2021 * 7 posts * 49 views 96-04 - 4V Specific Electrical nightmare November 15, 2021 * 13 posts ... Read more >>
November 17, 2021 * 41 posts * 533 views
joe65 said: I get Mokato's point of view on this and we can all admit that its not going to be free. there's just always some shit that doesn't work out no matter. After getting the 5.0 running ... Read more >>
November 17, 2021 * 16 posts * 218 views
Clutch Cargo said: Ha, no problem. In the past I was able to remove the console without loosening the bolts. Just thought it would make it easier. As an update to this thread as it appears not to ... Read more >>
Continue reading...
