SN95Newsletter
- Joined
- Mar 31, 2021
- Messages
- 463
- Reaction score
- 0
Click here to view on the web
Highlighted posts
August 30, 2021 * 43 posts * 238 views
Project Grey94 said: I'm also starting to think that the engine originally was replaced with a truck engine then I replaced it with a truck engine this car was beat down and abused by a kid whose parents ... Read more >>
August 30, 2021 * 16 posts * 148 views
ttocs said: while the car is high in its stock height when I had it at that height in Az there were still speed bumps I had to avoid as well as some intersections. When it rains in the desert ... Read more >>
August 31, 2021 * 10 posts * 68 views
Cochise said: I'm in the process of getting ready for the track. Not sure if I have enough time but I'm hoping to get everything together. Seeing since I just got the car and I don't have any ... Read more >>
August 30, 2021 * 7 posts * 61 views
Exhausts
PinkieT said: Funny thing is that you can get high flow aftermarket cats from Flowmaster and Magnaflow for $100 a pop and generics a lot cheaper. My 98s will age out of Ohio's smog check in ... Read more >>
August 30, 2021 * 7 posts * 49 views
ttocs said: maybe yer thinkin about us holley dudes with the digital dash and gps speedo? Or when white recently got a programmable gas gauge? I am not sure how you would go from gps to stock Read more >>
August 29, 2021 * 27 posts * 191 views
J_lope82 said: I have a little hand pump. My f150 has to be filled from the bottom as well . I'm kind of used to this way of filling up the trans. I'll be there for a while but oh well. Read more >>
September 02, 2021 * 2 posts * 27 views
96blak54 said: Car looks good. Definitely different. I like it! Did you get it for a good price? Read more >>
September 01, 2021 * 1 post * 10 views
SN95Newsletter said: Click here to view on the web Highlighted posts What is the sensor called on the back of the engine block passenger side please help August 30, 2021 * 43 posts * 119 views 94-95 ... Read more >>
August 30, 2021 * 8 posts * 124 views
ttocs said: if you suspect its the bag itself, try disconnecting it from the system and see if the err changes or if it stays the same. Read more >>
September 02, 2021 * 6 posts * 142 views
96blak54 said: I finished up all the work, got sick for a couple of weeks, dragged around for another week and now back at it again. Here is where im at now. Ive got the base fixture completed ... Read more >>
Continue reading...
