Highlighted posts from Thursday, Sep. 30, 2021
SN95Newsletter
Click here to view on the web
Highlighted posts
September 30, 2021 * 22 posts * 171 views
Notthenow said: Found it. Adjusting Clutch Cable Tension The goal of adjusting the clutch cable is to put enough tension on it to keep the throwout bearing in light contact with the clutch diaphragm ... Read more >>
September 30, 2021 * 16 posts * 109 views
Daryl said: So the guy from Accutach emailed me back with a few suggestions and things for me to check. Super nice of him to do that in lieu of me sending him the unit, getting charged for ... Read more >>
September 29, 2021 * 44 posts * 373 views
ttocs said: Yes if you have power on the correct ignition wires to power the ecu up you should be able to connect, are you sure that the version of the software that your using is correct/matching ... Read more >>
September 29, 2021 * 2 posts * 13 views
Clutch Cargo said: I noticed over time my 94 GT Convert tends to be missing more and more panel retainer clips, interior push pins and the like. Searches at Amazon and Ebay seems simple enough but ... Read more >>
September 29, 2021 * 1 post * 8 views
SN95Newsletter said: Click here to view on the web Highlighted posts 95 gt electrical questions September 28, 2021 * 19 posts * 60 views Electrical & Stereo Broken gauge cluster September 28, 2021 ... Read more >>
September 29, 2021 * 8 posts * 226 views
tmwsccsh said: Guess at the moment you're lucky if you can find a gas station open to get a photo at. Or certainly over here... TMW Read more >>
September 30, 2021 * 12 posts * 188 views
J_lope82 said: Well I drove the car a few days with the Pcv deleted and just a breather on the valve cover. The CEL is off now. However there is some fumes and heat coming out of the valve cover ... Read more >>
September 29, 2021 * 19 posts * 252 views
GTR said: I know this post is going on a month old but if you haven't decided I'll chime in. Scharder was the owner of the yellow mustang registry. Has/had a shop in NC. His rear seat delete ... Read more >>
September 30, 2021 * 97 posts * 2,870 views
Blitzwing said: Hi - do you still have the sun visors from a convertible? Read more >>
Continue reading...
Cwacaser
