Highlighted posts from Tuesday, Feb. 08, 2022
SN95Newsletter
Click here to view on the web
Highlighted posts
February 07, 2022 * 19 posts * 92 views
Adfalenski said: You can use a bearing splitter to remove the tone ring from the axle shaft and a piece of pipe with an inside diameter larger than the axle shaft diameter. You should be able to ... Read more >>
February 08, 2022 * 3 posts * 20 views
Duff said: I'll be replacing the lowering springs on my 95 cobra soon, going back to stock, any need to use a spring compressor for the fronts? Read more >>
February 07, 2022 * 3 posts * 27 views
Cochise said: So after ordering and returning 4 different seats. I have finally gotten the right ones for me. The Corbeau FX1's. Huge shout out to Corbeau and their patience. It literally went ... Read more >>
February 07, 2022 * 1 post * 10 views
SN95Newsletter said: Click here to view on the web Highlighted posts What the Sam Hill is this?? February 06, 2022 * 26 posts * 193 views 94-95 5.0 - Specific 96 8.8 axle shaft February 06, 2022 * ... Read more >>
February 07, 2022 * 7 posts * 725 views
Cobra82 said: Yeah I used a wiring diagram to trace down what I had to pull out the harness. There is a YouTube video of a guy that did the terminator x system on a 95 cobra and I tried to follow ... Read more >>
Continue reading...
