SN95Newsletter
- Joined
- Mar 31, 2021
- Messages
- 547
- Reaction score
- 0
Click here to view on the web
Highlighted posts
May 31, 2021 * 2 posts * 27 views
Daryl said: How do I know what capacity fuel pump I'll need after the engine rebuild and tune, assuming the one I have is the stock, 26- yr old pump? And should I get just a pump or replace ... Read more >>
May 31, 2021 * 16 posts * 226 views
ttocs said: how did you test it? Did you take it out of the car and put it on a charger and then test it a couple hours after its off the charger? I have seen batteries that once off of the ... Read more >>
May 31, 2021 * 1 post * 4 views
SN95Newsletter said: Click here to view on the web Highlighted posts 96 GT Won't start May 28, 2021 * 4 posts * 76 views General Tech TKX Swap May 30, 2021 * 17 posts * 310 views 94-95 5.0 - Specific ... Read more >>
May 31, 2021 * 9 posts * 209 views
weendoggy said: Before you throw $$$ at it, do a compression and leak down test. That way you'll know how good/bad the engine is. If all good, spend $$$.Read more >>
Continue reading...
