Highlighted posts from Tuesday, May. 04, 2021
SN95Newsletter
Click here to view on the web
Highlighted posts
May 04, 2021 * 14 posts * 223 views
joe65 said: yes fidanza is a good brand. been around for a long time and their flywheels are known to be good. Read more >>
May 03, 2021 * 5 posts * 60 views
Paladin1001 said: My daughter had to go to Reno from the area around Tucson last weekend so I went with her and we took her 98 GT. First long road trip on the car since I bought it a couple of years ... Read more >>
May 03, 2021 * 12 posts * 232 views
TrickVert said: Quite true,but that's the thing... I only rarely want it to be racecar. :) Read more >>
May 03, 2021 * 3 posts * 37 views
Randall Garner said: Just brought home a 98 convertible. The trans seems ok. But the engine has a bad miss. Going to get tune up and go from there. Not much experience with the mod motors. What other ... Read more >>
May 03, 2021 * 3 posts * 25 views
Blueraz_5.0 said: I've been bouncing between these two headlight designs for weeks now, so I'm looking for others opinions and maybe some votes. The car is blue, with black stripes, with a black ... Read more >>
88stang88 said: Over the weekend I decided to get back into the garage and put the Heads back onto the block (this has taken me forever to do due to kids and sports) and thought everything was ... Read more >>
May 03, 2021 * 9 posts * 355 views
amf201091 said: After replacing the 02 sensor, my CEL came back and was throwing P420 code (something with cats). My car is catless so I'm guessing thats probably why. I'm looking into getting ... Read more >>
May 04, 2021 * 1 post * 24 views
amf201091 said: I put two zip ties on the throttle cable behind the gas pedal in order to take the slack out and achieve WOT. Now the gas pedal rests way above the brake pedal when I have the ... Read more >>
May 04, 2021 * 1 post * 14 views
amf201091 said: My gas pedal was sloppy and had a bunch of slack so I added 2 zip ties to it. The problem now is I can't heel-toe because when I fully press the brake, it sits much lower than ... Read more >>
May 04, 2021 * 1 post * 0 views
SN95Newsletter said: Click here to view on the web Highlighted posts Flywheel during clutch replacement May 02, 2021 * 11 posts * 169 views 96-04 - 2V Specific Roll cage? May 02, 2021 * 11 posts * ... Read more >>
Continue reading...
peasant99
