Highlighted posts from Tuesday, May. 18, 2021
SN95Newsletter
Click here to view on the web
Highlighted posts
May 17, 2021 * 1 post * 18 views
Daryl said: Visually, it seems to sag down near the wheels, leaving very little ground clearance. Is there (or are there) alternatives that don't have that "sag", or are they all pretty much ... Read more >>
May 17, 2021 * 1 post * 5 views
SN95Newsletter said: Click here to view on the web Highlighted posts 1996 Cobra Water Pump. May 17, 2021 * 4 posts * 81 views General Tech Rear Main Seal Leak May 17, 2021 * 6 posts * 121 views 94-95 ... Read more >>
May 17, 2021 * 11 posts * 459 views
PinkieT said: OK, it's in the shop and they started taking it apart. Differential has a crack, spider gears are worn big time. No wonder it made noise! So far the gears in it look OK. They have ... Read more >>
May 18, 2021 * 117 posts * 2,362 views
ttocs said: Just keep it simple and ask them if they thought the power/torq was where it should be? I have to agree if it was fuel they should have been able to tell you and high flow cats ... Read more >>
Continue reading...
