Highlighted posts from Tuesday, May. 25, 2021
SN95Newsletter
Click here to view on the web
Highlighted posts
May 24, 2021 * 6 posts * 129 views
ttocs said: I am in the middle of my t56 swap now. How much work did you have to do around the shifter area to get it to fit? Stifflers makes a trans mount that uses the stock location. Read more >>
May 24, 2021 * 3 posts * 19 views
Daryl said: Can the drivers seat be set to a more upright position? I feel like even at the first click I'm leaning back further than I would prefer to be. Thanks! Read more >>
May 24, 2021 * 1 post * 24 views
joemomma said: After looking around and talking to several folks, I'm fairly well convinced that I want to go with a crate motor. My 302 has 156k on it, and while it doesn't smoke or use any ... Read more >>
May 24, 2021 * 1 post * 4 views
SN95Newsletter said: Click here to view on the web Highlighted posts 96 Cobra. Low compression on 3 cylinders. Please Help. May 21, 2021 * 14 posts * 159 views 96-04 - 4V Specific Battery selection... ... Read more >>
May 25, 2021 * 11 posts * 467 views
TrickVert said: That's the main line to the vacuum manifold at the rear of the driver's side fender. The fuel pressure regulator line is also attached there, but isn't visible in that picture. ... Read more >>
Continue reading...
