Highlighted posts from Wednesday, May. 19, 2021
SN95Newsletter
Click here to view on the web
Highlighted posts
May 18, 2021 * 13 posts * 125 views
skidoo said: Picture? I bought the Ford Motorsport kit that had shocks, springs and swaybars and it sits pretty tight. I'll try and snap a picture later on. Sent from my Pixel 5 using Tapatalk Read more >>
May 19, 2021 * 8 posts * 165 views
Road_Runna said: Felpro seals also have the spring that loops around the inside lip of the seal. There's also the special tool that greatly helps pulling an old one out,H recommend it for future ... Read more >>
May 18, 2021 * 1 post * 4 views
SN95Newsletter said: Click here to view on the web Highlighted posts Alternative to Eibach rear sway bar? May 17, 2021 * 1 post * 18 views 94-95 5.0 - Specific Highlighted posts from Monday, May. 17, ... Read more >>
May 18, 2021 * 11 posts * 459 views
PinkieT said: I have 3.73s right now. Based on my driving, I decided 3.55s were the best choice. Besides, they are already bought and in the shop. Read more >>
May 18, 2021 * 8 posts * 427 views
Chenn2389 said: I first ordered the FRPP efi covers for the fox, but they didn't work fill tube was moved much closer to the throttle body than the stock fox covers. I went with the trick flow ... Read more >>
May 19, 2021 * 117 posts * 2,362 views
ttocs said: Can you get a video of the startup? It should rev up a little and then drop down to the idle rpm but not go up/down after that. now to really have a battery tested you need to ... Read more >>
Continue reading...
