Highlighted posts from Wednesday, Nov. 03, 2021
SN95Newsletter
Click here to view on the web
Highlighted posts
November 02, 2021 * 24 posts * 99 views
Makoto said: I'm going to do some more testing today because I was thinking maybe my battery relocation situation could be the issue. The setup shows zero voltage loss so I think we're good ... Read more >>
November 03, 2021 * 14 posts * 126 views
Buffalo5Spd said: The rear motor was an open circuit with no power passing through when tested. I had power to the motor but it was dead on the other side as if the wire broke on the inside. I actually ... Read more >>
November 02, 2021 * 5 posts * 40 views
Boosted_97Cobra said: So currently I have a 1997 cobra forged internals. Innercooler, imrc delete, adjustable fuel regulator, 47 psi injectors, 255 warlboro fuel pump. 3.0 inch pulley on a 6 rib belt. ... Read more >>
November 02, 2021 * 6 posts * 68 views
Jakespeeds said: Per the way the California regulations are written you were illegal in this stoopid state. That is considered a modified exhaust. I would never go to that smog station again. There ... Read more >>
November 02, 2021 * 31 posts * 400 views
88stang88 said: I think this is the route you will be heading if your sticking with the setup in front of you. Source the following: K-Member Mustang Headers Mustang Oil Pan and pickup tube A/C ... Read more >>
November 02, 2021 * 7 posts * 98 views
tvsn95 said: Think this way,,A larger TB will allow more ar in IF you are restricted there. Aftermarket makers always tell you that it makes more,. But if you buy all the "stuff" that claims ... Read more >>
November 03, 2021 * 3 posts * 17 views
d.garza18 said: I need some pigtails for my car. Both cooling temp sensor pigtails on intake manifold, crank and cam sensor pigtail, driver side coil pack pigtail, water pump, coil packs, plug ... Read more >>
November 02, 2021 * 1 post * 10 views
SN95Newsletter said: Click here to view on the web Highlighted posts 03 GT Convertible Power Windows November 01, 2021 * 8 posts * 38 views Electrical & Stereo Motor Break In October 31, 2021 * 7 posts ... Read more >>
November 03, 2021 * 1 post * 7 views
SN95Newsletter said: Click here to view on the web Highlighted posts 03 GT Convertible Power Windows November 02, 2021 * 13 posts * 96 views Electrical & Stereo Car is tuned, runs great, at idle it ... Read more >>
November 03, 2021 * 11 posts * 168 views
Road_Runna said: Stock timing at °14 degrees? I read somewhere that stock is set at °10 degrees. Infact, after my T5 swap my timing idled perfect at °10 degrees with the T40MO computer. I tried ... Read more >>
Continue reading...
jjD417
