Holley Systemax II
el docum
Hello,
I want to know if some body as already install this kit :
Holley Systemax II:
The price is $2259.00 at Summit, I know that the kit is made for 86-93 Mustangs, but maybe it fit in a 94-95 if I remove the Strut Tower.
For the price is it a move?
Thank's
Francis
I had the intake on my 91GT with stock heads and a E303 cam...........it sucked :mad: :mad: Its not the intake that was the problem it was the lack of aftermarket heads that was the problem. The ports on the Holley intake are HUGE so the stock heads were causeing all kinds of trouble. With the quality of the intake im sure the entire kit of cam and heads would be a great set-up and make big time power.
ryclef331
el docum said:
Hello,
Holley Systemax II:
Thank's
Francis
It will fit with the strut tower bar removed and you also have to pick up a throttle body adapter as well to mate up with the SN95 inlet. Its a good set up though
E
el docum
Hello,
Thank's for your responses, do you think that I can keep the original hood?
I don't like aftermarket fiber hood look, so I prefer to conserve the stock one.
Francis
txlen
you'll have to do the fox throttle body conversion also...iv'e done it..no big deal...
E
el docum
Hello,
Thank's, maybe it's even a better kit :
I go to my speedshop today, they said that I have also to buy a new fuel pump and better injectors (24 lbs.)
Francis
97vertstang
looks like it has more parts and trick flow parts are proven to work, while i havent seen too much about holley on the 5.0s.
senior001
