HOW MUCH BOOST CAN A 4.6 TAKE?
bottlefed97
Orlando, FL
My dad and I just finished putting the new motor in my 97 GT. It has a 98' NPI block, rods, crank, pistons, .030 shave P.I. heads, P.I. cam, P.I. intake, full exhaust, 75mm TB and plenum, and a CAI. It has roughly 60,000 miles. I sprayed my old stock 97 NPI motor with a 125 wet shot at least sixty times down the strip and it ran fine. I was thinking about getting a low boost vortech kit for the new motor, but people are telling me that it wouldn't hold up. Would six pounds of boost be too much??? Thanks!
Matt
justinschmidt1
I think the stock internals would be fine at 11-12 psi with npi.
But your pi swapped and your compression is higher so your limited.
nesqwick_05
brightwhite98GT said:
I would say on stock internals, no more then 8 pounds. I think that would be pushing it a little.
where do u get that idea, id like to meet this person who says that 8lbs is pushing the stock motor :idiot2:
Really? Quite a few people have told me. I dont know, maybe they were refering to my car specifically when they told me, because my car is high mileage (105xxx)
justinschmidt1
Hmm I think it would be more the condition of your motor than the mileage anyway...and from what ive heard boosting these motors with high mileage is not a problem.
Im gonna be boosting mine with over 105k
voidfinger
Since you got the pi swap... and at .030 shaved... you will not want to go over 8 and if so i wouldn't dream of taking over 10... and you better have a spot on tune. But I've driven a coupe with the pi swap and an 8 pound S trim and it was like a totally different car than a PI with 9:1 and 8 pounds. Felt kinda like 14 or so #'s to the back tires :dancing6:
Dalamar
SLC, UT
Yes, as stated, 8# with your higher compression.
and watch out for any detonation. a few seconds on the stock rods and you'll be looking at a new shortblock.
nesqwick_05
in reality, no boost is safe boost. but if you wanna be able to get by id say 10-12 is safe on the stock pistons if u are tuned for it. if u run an fmu 8-10lbs. question isnt will it blow, its when, it will give one day or another, but u can improve longitivity by simple tuning.
the motors were not made for boost, u think it will live forever with it?? kinda like a midget, they where not born to play basketball, u think they will make it pro?
voidfinger
If you get forged internals you should be good... b/c these mod blocks are strait up beef dude. Kicks the 5.0 blocks in the nuts and walks away.
97stanger
boost is only a measure of restriction, it should be the rwhp/tq that you worry about. boost is just a number.
GDawg
I'm running a 9psi pulley on my stock '98... but I'm at 6,300 ft above sea level so I doubt that my actual boost is that high. I have yet to be able to find out for sure. I'm going to bump her up after a professional tune once I can find some fucking work around this deadbeat state.
justinschmidt1
yea, boost is pressure..pounds square inch..you dont want too much pressure in your engine/
Ive heard that anything over 400hp is risky with a 4.6 450 rwhp+ is bad news.
But I wouldnte feel safe running 15psi on my stock engine, even if I only made 370 hp to the wheels.
97stanger
it all depends on the tune. thats the most important. every single car is different. I know guys that have blown their motor at 360rwhp and others still running 440rwhp and never had a problem. also depends on how bad you beat the car. My tuner told me to go no higher than 425rwhp.
Jrgunn5150
The Man beat me to it. You toher guy's remeber, he's at nearly 11:1.
voidfinger
370 rwhp is probably over 400 on the motor :thumb:
lizzyfan
I/C or meth is a must in this situation!
bottlefed97
bottlefed97
Orlando, FL
So basically as long as I get a good tune, keep the boost and horsepower down below 350 wheel and around 8 psi, and don't beat on the car all the time, I should be ok?
