How often do u use RESTORE?
YUNG VEEZU
Ft. Carson, CO
I've only used it once, my stang has 126,000. I heard some guys use it every oil change. How often do u guys use it?
98mstanggt
Louisiana
When i had my other mustang i used it every oil change it had 147K miles on it when i got rid of it i never had not one single mechanical problem at all i brought it at 100K. I dont know if thats cause of the restore of what but it sure made me feel better putting it in the car.
x182dan
The stuff actually works real good but if your motor is in good working order you don't need it.
adrift
Is this something you'd use before or after your engine is working "real good"? In other words, by the time you have engine problems, will it be too late?
blackpony
id recommend every other oil change... i used it on my old 5.0 and was very impressed with the results.... raised the compression ratio on average of 10 lbs per cylinder....
