I have the P1443 code
96 VERT
Marietta, Georgia, United States
So i have the P1443 code, i have looked around and figured out that i have a cracked hose some where so i have a vacuum leak, and its $60 for a vacuum test to figure where the leak is, anything else i need to know
Willis_98GT
DFW Texas
i have the same code and just changed the evap cannister and it came right back if that helps, im about to do the purge solenoid
joekd
Ct
For $60 I think it would be worth it to run the test and make sure lines arent split/cracked before you start throwing new parts at it
Willis_98GT
DFW Texas
well you can also just buy hose and redo the lines just for safe measures, its very easy to do. its one line that comes in from the passenger side fender and goes to the canister then goes to the purge solenoid then the back of the plenum.
GDTrumbo
Nashville, TN
The OEM (Echlin) flow sensor & purge solenoid are available at NAPA. They are exact replacements and sport the Ford logo.
GT
AaRoN
King Post Whore
The P1443 DTC refers to whether or not you have flow and how much flow you have from the Charcoal cannister. If the flow sensor doesn't detect flow or enough flow, it will set the MIL. If you replaced the solenoid, unhooked your negative cable from the battery ( for at least 10 min.), hooked it back up and the MIL comes back; then it is most likely a faulty flow sensor.
Do you have a multi-meter or access to one?
WarHorse
P1443, I hate this code only because i hate seeing my check engine light on. This thing came on every time i gave my car a good stomping, the code said it read a fuel pressure increase higher than blah blah blah or lower than blah blah blah.
Long story short I replaced the purge flow sensor, and a few hoses and its been a while since its come back on. Lets hope it stays that way.
Your best bet is to replace any hoses that may look cracked or worn, this is in no way a waste of money because used, cracked, and worn hoses need replacing anyway and they're cheap. Then clear your code and if it comes back on then you can look into replacing sensors.
96 VERT
sounds good to me man, thanks
