vinniepearl
- Joined
- Jun 13, 2008
- Messages
- 154
- Reaction score
- 0
I drive a 94 gt 5.0, I want to build a new engine. I'm wondering if all the 302 blocks are the same? I've found a 1982 HO block. Will this work with all of my current parts?
Mr. OAM said:The 1982 block is NOT a roller block. It is a flat tappet block. To stay with a roller block like you have you need one that is 1985 or later. If you plan to use stock pistons stay away from the 1986 block with it's flat top pistons because you are limited on cam lift and cylinder head selection with these engines.
How much power you looking to build and how do you want it to behave? That will determine the block choice.
Mexican blocks can be like finding hen's teeth sometimes and may not be needed anyways. Of course they are also not roller blocks. You can put a retro-fit roller kit into any non-roller block though. In that case the 1968 302 block was also very good.
Steve
