Loss of Power
Christang95
When I?m running my car at WOT the car cuts out with sputtering and backfire. This only happens when im at wide open throttle and above 4,500 rpms. I?ve tried many things to fix the problem; new Cap, rotor and wires. Cleaned Mass air sensor. My best guess is the fuel pump is going and can no longer produce sufficient fuel pressure at wide open throttle at high rpms.
C
Christang95
Spark plugs are new, ignition coil not sure, fuel filter brand new and air filter is cold air and seems good
wannaboost94gt
Maybe youe fuel injectors are a bit dirty, you could try running some Seafoam engine cleaner through it it's worth a shot, just don't put any in the oil use 2/3 sucked up through the vac line and put the remaining 1/3 in the gas tank. Enjoy the smoke show!
wannaboost94gt
You gotta keep it at like 3000 rpms whaen sucking it up or it'll die do a lil bit at a time it's kinda a 2 man job.
C
Christang95
I rebuilt the injectors with new o-rings and pintle caps a few hundred miles ago. I also ran a injector cleaner a few tanks ago.
C
Christang95
I'm not sure, The motor is out of a wreck and they guy I bought it from didn't know the mileage.
