Misfire issue
torch318
Dealing with a misfire on cylinder #1 and a coolant loss issue. I did a compression test and it was normal and there is no bubbling in the reservoir when the car is running. I bought a harbor freight leak down tester but I don't have a large enough air supply to get an accurate reading with it. I did a radiator pressure test and it holds 15 lbs. I was wondering what your guys thoughts were, I am thinking I lifted the head or have an intake manifold gasket leak and just wondering what the best way to diagnose the problem would be.
Sent from my SM-G900R4 using Tapatalk
Staff member
Intake gasket leak would definitely cause the problem. Cylinder 1 is right there by a water port. The intake comes off pretty easy, I would pull it and see what the gasket looks like.
torch318
torch318
I'll try that and see.
NEURON
SOCAL
The coolant is just disappearing leaving no signs of where or why? How much is it loosing? Since the COPS are dry then it must be two separate problems. You could try swapping the COP around to see if it travels with the COP. System is holding pressure and no signs of leaks, I might suspect the pressure cap or leakage from the radiator at the plastic end caps/aluminum finning. Not to depress you but I have '99 ZX2 that has been loosing about a quart or so of coolant every few weeks since I bought it 3 years ago and have put 23K on it including three 1K plus trips, not sure how that can even be happening.
torch318
torch318
Ive changed plugs and moved the COPs and the misfire doesn't follow. On a 20 min drive keeping the car out of boost the reservoir will go from full to just about empty and the car will smoke excessively if I wot it. Using a radiator pressure tester it held 15 psi for about 10 mins with no signs of leaking.
Silver95bird
How much boost does this engine max at? If it is burning coolant, you'll know because the O2s on that bank will fail and that side will run pig rich. What did the #1 plug look like before and now? Have you been checking the oil for signs of that oil/coolant milkshake?
torch318
torch318
The car makes 17psi max boost. I don't have the old plugs but here's a pic of 1 and 2, 1 has a whitish yellow look to while 2 looks normal to me but they only have about an hour of run time on them. The oil looks normal with no signs of coolant.
NEURON
SOCAL
Is the smoke whitish? Sounds like a head gasket but doesn't show any of the signs in your testing, weird.
torch318
torch318
Yes the smoke is white.
That's been every issue with this car since the motor build. Last issue I couldn't figure out, local shop couldn't figure out then I hauled the car back out to the tuner and it sat there for 9 months before he got it done...
torch318
torch318
Well I pulled the intake and I don't see any obvious signs of gasket damage to be the cause of the misfire.
Staff member
Are your heads ported? [MENTION=20979]OLD H2S[/MENTION] found out the hard way that the wall on the ports will get thin and put coolant in the intake port after the head gets hot.
Staff member
Lawrenceburg Kentucky
That does look like coolant residue on the ground strap. Scrap it with your finger nail?
Both plugs should look the same. The dirty ceramic is a clear indicator of a sparkplug not getting to self cleaning temperature but thats not saying the plug with coolant scabs is cleaning. Moisture in the cylinder will clean out the carbon. Take out all the plugs, keep the numbered to the cylinder. All plugs should look very similar.
A small coolant leak may only happen when into the rpm's causing the head to lift.
Might be improper deck surface roughness finish for the headgasket not letting the headgasket do its thing. Headgaskets require a certain roughness finish of both deck surfaces to maximize holding potential. A combination of headlift and gasket release lets water weep into the cylinder.
