Mustang GT Weld in bung...
Autumnstang97
San Francisco, CA
Where can I get weld in bungs for coolant temp sensors for use on 96-98 GT/Cobras'?
I need to weld a second bung on the coolant crossover on an 03/04 Cobra which only has one, bc I am re-using the 97 GT engine harness, which has two connections for coolant sensors.
Or if anyone knows the size of the threads.
I found this...would this work?
http://www.dallasmustang.com/mustan...-Female-1-8-NPT-Steel-Weld-In-1964-2014/20390
Thanks.
kb1982
Kentucky
I would go to a local auto parts store and tell them what you need the bung for. They probably have the sensor and can try various bungs they have for fitment. Are you sure they are both coolant temp sensors instead of one being an inlet air temp sensor and the other the coolant temp sensor? If they both are coolant sensors, just tap into the wires and use the same sensor for both signals. If you go that route, do it right and use heat shrink and solder.
SMOKEDYA
Tucson Az.
are you asking the size of the threads on the bung you put a link to? If so it's 1/8th inch national pipe thread (NPT). Which if I'm thinking of the correct sensors its the same.Or are you thinking of using the vent bung on the crossover tube?
