my car
ellerstang
Kingsville, Tx. 78363
hey guys this is my what started out to be a v6 running 17.1 in the 1/4 to a 5.0 running 12.6 in the 1/4
my car is done right now im going to upgrade the hole car
mini tubs 9 in. roll cage, 5.8 w, single 88 turbo setup
wish me luck
E
ellerstang
right now its running 12.62 in the 1/4 mile at 103mph
you can check out a video of it on you tube title called
texasdragracing10/24/08
im in the left lane in the first two runs
E
ellerstang
its the cobra r hood 3in i belive
what i had done to it is stock rear end
it use to be a v6
smog pump delete
ac delete
et street tires
t5 with pro 5.0 short shifter
zex wet kit
f-303 cam
bbk long tube headers
bbk 70 mm throttle body
msd distributor
9 ford racing spark plug wires
fluidyne radiator
6al msd box
Kirban Fuel Pressure Regulator
24 lb ford racing injectors
255 walbro pump
strait pypes with dumps after the supper 44's
and belive it or not but this motor has over 300 thousand mile put into it
i think that about does it
working on a new setup for my car now
wish me luck
and thanks new to this forum saw one of its videos and had to check it out
Hoseitdown
what kind of wheels are those in the 2nd pic? are they year specific or what?
E
ellerstang
those are the cobra s200 y2k wheels in the second pic
my 60 ft was 1.8 but i have cut a 1.6 before
my car is at 3200 right now but with me in it so it is an even 3000 i weigh a little over 200
this is what i did to the back seet of my car
cut out two hole out on the back bored and put two power refrence in there
and my trunk is gutted out
E
ellerstang
150 shot
they say zex only does it to the fly wheel so probably its more like a 125
i was going to try the 175 jets the day before i sold my engine and tranny
but my friend i dont know if u looked up the video on you tube (texasdragracing10/24/08) or not but the guy i was racing in the first two races at the end had a nitrous back fire and couldnt afford to blow mine so i loaded his 98 on my trailor and he drove my back home for me
wish i would of tacken the chance though
i was running 13.01 consistant until i upgrade my fuel regulator and injectors and got a y band and a afm pms 3(anderson ford motorsport tuner)then i broke into the twelves very easy
that night i ran four 12.76-12.79 and one 12.61
