a while back i was planning on a 408 + stroker cause i could get the internals for a good price but i found a set of forged pistons and eagle h-beam rods for a 30 over 351 for a hell of a deal i couldnt pass up, now im looking for a cam that would work well with it, i would get a custom grind but im too damn cheap to spend the extra amount for one, so i just like to get some opinions on a good off the shelf cam that will work well with the set up, im keeping the stock roller set-up from the 5.0, the same heads and 1.72 rockers i already have, the compression is going to be 8.6:1 or so and the motor is going to be boosted pretty well, according to pulley sizes it says the psi will be around 16-17, but i wont know actual psi untill its running, the valve springs in the heads now can handle up to .550, i can get new springs if needed, id like to have a cam with a strong duration and higher lift if it would work well with boost, thanks
