Normal idle vacuum reading on a boost gauge?
<blockquote data-quote="Lee12609" data-source="post: 751837" data-attributes="member: 12415"><p>what makes you think i'm presuming you're an idiot? i was giving factory stock specs, of coarse there are TONS of variables, hence the reason i asked "which cam", also why i said all gauges arent created equal.</p><p></p><p>simply put if the stock cam is only pulling 14 in/hg at idle the motor is getting loose, there's a vacuum leak, or a valvetrain issue.</p></blockquote><p></p>
[QUOTE="Lee12609, post: 751837, member: 12415"] what makes you think i'm presuming you're an idiot? i was giving factory stock specs, of coarse there are TONS of variables, hence the reason i asked "which cam", also why i said all gauges arent created equal. simply put if the stock cam is only pulling 14 in/hg at idle the motor is getting loose, there's a vacuum leak, or a valvetrain issue. [/QUOTE]
EGR Tube--How to get it sealed on the exhaust manifold?
Yesterday at 11:20 PM
Exhausts
Leaky oil temp sending unit
Yesterday at 10:35 PM
Latest: ttocs
Yesterday at 7:50 PM
Transmission problem
Latest: Bronco2Fan
Yesterday at 5:17 PM
Community News
Converting a small block 94/95 from MPFI to TBI - in case anyone else wants to go this route
Yesterday at 4:15 PM
R.C.
