O2 Sensor Gone Bad?
Ohio
Here recently my car feels... well sluggish i guess is the word. Sounds different in a bad way, and i feel my gas mileage and suffered as well. I did install an off road xpipe but that was months ago and this problem just started about a week ago. I would have to say this may be an o2 sensor. is there any way to check and see if this is the case?
only way to see if an o2 is bad is to check the wires for breaks/tears or if it throws a code. other than that you'll just have to replace them.
SneakySonBeach
Ohio
MIL eliminators will cause it to run in a slightly rich setting, causing slightly worse MPG.
huh, well i've had those on since may and this problem only just occurred last week? I just tried to clean the MAF and though i did get better throttle response it still boggs down. any other reasons why this could happen?
open gas cap.
place in funnel.
pour in can of sea foam.
fill tank with premium gas.
drive until near empty.
fill with mid-grade gas.
replace spark plugs, diagnose spark plugs.
if you replace your o2s, do it after the seafoam.
np man :) Be ready for SMOKE when you run it through the intake manifold... its like a CIA attack on your car. lol.
here's a how-to on putting it in the intake.
**BE sure to read the insturctions on the amount to put in** this dude put in the entire bottle, not sure if thats right...
http://www.youtube.com/watch?v=YFKNRma-ozE
SneakySonBeach
Ohio
