If anyone reads this later, the system I have is now called Prometh. It is a super simple system. The pump is mounted to the tank in the trunk and there is a feed line to the intake manifold after the throttle body. Power is connected to a boost activated switch at the com or common connection at the top of the switch. The other two connections are labeled NO for normally open, and NC for normally closed. The pump is connected to normally closed. The switch has a screw which can be manually adjusted and sets the boost level at which the power connection to the pump is made which in turn delivers the methanol to your intake. The pump is grounded to the body of the car.
Fun note: it appears the methanol from back in the day was just windshield washer fluid, rated at -20 degrees. Make sure to read ingredients and it'll show the 50-55% meth mixture. Wild!
