patriot performance?
mdsn95
has anyone ever heard of patriot performance heads? if so are they good and worth buying??
2002BLGT
Bedford VA
I would not buy their 4.6L heads , I had a set that had leaky valve guides/seals , brand new out of the box , burned oil from first startup , SUCKED , never seen anybody with that issue on a 5.0 but I would be leary after my experience
LAFENATU
Garbage.
They source from off shore countries
There was a big thread on the Corral about Patriot heads that was back and forth so finally Jason @ AFR ordered a set of Patriot heads at his home address. He took them to the shop @ AFR and had them flow tested. Here are the results..
Here were the flow numbers off our equipment using a Brezenski radiused entry on the inlet side and the same flowtube we use on all our SBF / SBC testing on the exhaust. By the way our advertised data on our 185 exhaust is old and doesn't reflect the addition of a flowtube which adds 10-15 CFM across the board. Tony is going to flow a 185 production part early next week to provide a good comparison. In the mean time I have included info from an AFR 165 head we spot flowed a few weeks ago?.note this head only has a 1.900 intake valve (Versus the 2.02" in the Patriot).
Patriot 185cc (as cast 2.02/1.60 Valve)
Lift?INT / EXH
.200" 141 / 91
.300" 194 / 131
.400" 218 / 159
.500" 233 / 169
.600" 245 / 175
(Yes the exhaust numbers are correlated with the right valve lift).
AFR 165 (CNC 1.90/1.60 Valve)
Lift?INT / EXH
.200" 133 / 122
.300? 190 / 162
.400? 230 / 189
.500? 248 / 198
.600? 254 / 205
Im sure this is going to be a controversial post but it is what it is?.
Jason Dow - Airflow Research
mdsn95
yeah i have a 5.0 but wow after those results dont think so, thanks
