Paul's Powdercoated Valve Covers - Pics Inside
Paul
So someone mentioned the valve covers that I make in my spare time in another thread, and I got a bunch of PM's about it - sooo, I thought I'd make a thread about them.
I have my own powdercoating setup in my garage. I've been doing it now for about a year and a half or so, and I'm getting halfway decent at it.
When building the motor for my notch, I wanted someone clean and "sanitary" looking. I also hate the way tall valve covers can complicate intake fitment and whatnot. I really like stock fox valve covers because they seal well, clear roller rockers (with the baffle removed), and can look really nice if you spend some time on them.
I start out with ordinary foxbody aluminum valve covers. These have already been either glass bead blasted, or spent fifteen minutes in a Wheelabrator shot-blasting machine. They are cleaner than new, but have tons of casting flash and are just generally not very smooth.
Then I spend FOUR FREAKING HOURS sanding the crap out of them. Seriously. That's PER SET. This is all done by hand with a Porter-Cable vibrating sander, and a half-dozen different die grinders and other implements of destruction that I have. They are well-suited for the task. First they get 40 grit, then 60, then 100, then 150, then 220 grit. Here's some pictures of prepped covers at various stages:
After I've successfully wrecked my garage and there is aluminum dust everywhere, (and no doubt sitting in my lungs and causing cancer right now) I clean them up with oodles of brake cleaner to prep them for the oven. They get pre-heated, then taken out, and coated with what color powder I decide to use. This is a chrome powder before it gets melted in the oven.
Then after curing in the oven at 385* for 18 minutes, then come out and cool down.
Here's some silver metallic covers. (Matt94GT has these)
This is Columbia single-stage Chrome.
This is Gunmetal Gray. (I have these on my motor)
I want to try some new colors next time around. I'm going to do some in Ultra Mirror Black like this big block Ford tunnel ram intake I did for my friend.
I also want to try a set in a candy translucent color. These colors are a real pain in the a*s because I have to do an Xtreme Chrome base coat, cure for a LONG time, cool all the way to room temperature, re-heat, then coat the candy color. That's a real b|tch because you have to have perfectly even coating all the way around or the color won't be even. Nooks and crannies are near impossible because the Farraday Cage Effect keeps the powder out. I want to try some in the Candy Red Translucent like these pulleys I did for a very good friend of mine.
I've been selling them for $110 a set shipped to the lower 48 states. It's not really worth it because of all the time I have to put into them, but for me it's more about practicing my coating, and seeing what new colors look like. I need to do some more sets soon.
Paul.
wytstang
Put me in line I want gunmetal ftmfw. I need a set modded for 94/95 alt problem and would also like a matching oil cap.
Anyone know if scorpion RR fit under these? If and I do mean if I ever get heads I would like to run Scorpion 1.6 RR.
95-stang
I did,nt have to mod mine for anything, i hope your as lucky.
P
Paul
I think I have a couple sets of covers at home that I can coat. If you REALLY want some, then PM me and I'll send you my paypal address. I'll make them up this weekend and send them out on Monday.
A few notes:
1. They clear roller rockers (at least they do on mine)
2. They clear the 94-95 alternator because they taper up at the edge.
3. I've been told they clear the 94-95 intake tract, but haven't tried it myself. You can take your oil fill cap apart to make it "smaller" and easier to clear the air inlet.
4. They're $95 shipped to the lower 48. You don't have to supply your own covers. I'll send you the baffles if I have them, just in case you want them.
Paul.
P
Paul
No, but it is clearly 94-95 specific, and is tailored to this particular audience. :grin:
Steven
SC
Looks good buddy. I might hit you up when you get some sets. I wouldn't mind like a flat black/crinkle look.
ReplicaR
Looks great Paul. How long would be a turn-around time to do Edelbrock intake manifold cover, and what would be the price?
I'm talking about the object in red circle.
P
Paul
Powdercoating by mail isn't really worth it because of the cost to ship both ways. I recommend you guys look for a local powdercoating place - most of the time the prices are very reasonable.
Steven
SC
This is a bit random, but it's funny to me to see you have the same exact bench wire setup that I do, and that it likes to loosen up and get crazy on just about everyone. lol.
armyed
Wow..looks like you do some really good work. My brother has a powder coating system but I may just have to buy from you so I don't have to do all the work! lol
