Pinion flange
jwhisl
Oklahoma
Hey everyone. I'm in the process of replacing the pinion seal in an 03 Cobra IRS. I got the seal in but I can't get the flange to seat properly. I've tried to clean all the silicon out of the teeth from the previous owner. The flange stops maybe 1/16 of an inch from being completely seated. I've tried running down the old but to force it, and an 8lb sledge and 2x4. I've also removed the flange 4 times to check for debris or damage. Need help
lwarrior1016
Mr. Secondary Timing Chain
Staff member
South Mississippi
Ok, so very first thing, please stop hitting it with a hammer. You’re going to damage the teeth on your pinion gear if you haven’t already.
Next, the pinion flange should not have silicone in it. Inspect your flange very closely and see why they did that.
The flange should not go on easily. It has to be pulled in to place by the pinion nut. The flange should go on, maybe half way by hand and then use the nut to pull it on the rest of the way.
J
jwhisl
Oklahoma
The previous owner was trying to stop a leak. I've tried using the nut and even an impact. I've removed the pinion 4 times now and inspected for damage each time. I'm waiting to hear back from someone that might come out and look it over.
lwarrior1016
Staff member
South Mississippi
If it’s been leaking this long, something is wrong and you probably need a new pinion flange.
Do you have the rear cover off?
It sounds like the outer pinion bearing may not be seated straight on the pinion shaft.
You may have to pull the seal out and remove the outer pinion bearing, then reinstall it and make sure it’s straight. Don’t forget the oil slinger that goes behind the seal.
shurur
Iirc when you remove the nut, you are supposed to counts the number of turns, so you don't put it on too tight. Some say tighten it another quarter turn; others go ape when they hear that being said..
