Powersteering
waltnono
Southside Chicago
I need help getting my hydroboost setup can someone tell me if i'm in the right directing.
The upper right fitting goes the 12 oclock fitting on the hydroboost right?
The 8 o'clock fitting to the powersteer reservoir
This is the line that goes to the 8 oclock fitting on the hydroboost. You can see the tee on it that goes to the reservoir and the other line goes to the radiator right?
Now is this the line that goes from the 6 oclock position to the powersteering pump?
Now if this is correct, where does botton right line on the powersteering rack goes? Is it the radiator? Ok now on the radiator there are two lines, which is the supply and which is the return
alleghenyamerican
Staff online
