Problem with engine
buddah4096
I have a 308 with a carburetor, with an old msd set up,with a c4 I just replaced head gaskets, got rockers adjusted a little loose, it ran good, I drove it done the rd it had just rained I have street ets on rear I was in first it spun revved up to 5500 i let out put it in second and it started missing bad, I've adjusted rockers replaced plugs, just got done replacing lifters tonight, it still has miss and has a popping sound when I give it has like an exhaust leak but I've tightened all bolts on exhaust, the lifters looked fine on rollers on one's I took out, the heads are trickflow twisted new, I have no clue what is going on
Orange 94
Alberta Canada
Welcome to the forum. This doesn't belong in community news. Moved to pushrod section since that will likely be the most helpful.
Have you replaced plugs, wires, cap and rotor since it started missing?
Look for moisture under the dizzy cap.
Welcome to the madness.
DriftCafe63
