racing oil pan
mike stevens
I'm going road racing. I have been looking for a road racing pan with no luck. Evidently there is a fitment problem.
what is the fitment issue? Has anybody come up with a work around?
any tech help would be appreciated.
Mike
OLD H2S
Silver Spring Maryland
I have one from MMRI am not using so go look it up. Not much for baffling but it hols more and is about 1/2" lower.
MTRHDROB
I use a fox body Canton T style pan on my 95. Clutch cable runs into some interference on the pan. I ran it that way with no issues but it wore on my brain. I ended up making a bracket to run the clutch cable outside of the bellhousing and extending the clutch fork to match. Been working great for at least ten years now.1DD1C0D8-727C-4929-A2D3-DD25BC18DDCA.jpeg7D24E674-B2F0-4A67-BCE2-59B8E4E711C3.jpeg
MTRHDROB
If you are asking me if I have a stock k-member, I did at the time this was done. I am now running an MM k-member with the same setup.
mike stevens
Great help guys! I was concerned about oil pickup in the turns at 1G plus.
Mike
