Radiator
CanaryGT
Phoenix
Which one should I buy?
Im in cali right now and on the way here, she got kinda warmer than I wanted. Im lookin for a new raditor to perhaps solve some of the problems. I hear Fluidyne all the time, but I hear mixed reviews.....
reivaxtorres
buy an 03/04 cobra radiator. thicker and all aluminum instead of the aluminum/plastic of the GT ones. doesnt work on auto's unless you have the seperate trans oil cooler.
CanaryGT
CanaryGT
Phoenix
As well as the radiator, what else should I purchase to increase my cooling?? Thanks for the info!!
AaRoN
King Post Whore
get yourself some water wetter, lower degree t-stat. if your in a warm climate, increase your water-coolant mixture 60/40. manually wire your fan to a toggle.
Paul
Here's some options:
1. Evans NPG coolant, but you'll need to get ALL the water out of the system.
2. Meziere electric water pump
3. Buy a very high pressure cap (can be had from stockcarproducts.com and similar)
4. I think Stewart makes an upgraded pump for the 94-95 now, but I can't remember for sure.
However, you'll probably be fine with what you've got. :)
Paul.
CanaryGT
CanaryGT
Phoenix
Ive heard of that Evans thingie. Sounds pretty nice..... Also, does anyone make silicone hosing for the 94-95 mustangs? Like the Blue silicone hosing from ford racing??
Paul
Yep, to my knowledge it's a direct replacement.
I paid $26 per gallon for the Evans NPG, plus it's not very easy to get EVERYTHING out of the cooling system, so it may not be worht it for you.
Black rubber hoses are fine, I wouldn't worry about them. You can change them in another 100,000 miles. :)
Paul.
QTRHRSE
03 Cobra > Mishimoto
nothing fits like factory... and the Cobra is PROVEN to be damn reliable with tons of power
916_5.0
Do the 03-04 cobras fit directly in to the push rod cars? like exact you dont have to run hoses diffrently or anything.
