Realistic gains
<blockquote data-quote="Sn95289" data-source="post: 1424520" data-attributes="member: 22077"><p>You can look to get 20-25 hp right of the bat but if if you put good tune you can look closer to 30. Advance timing and add fuel pressure to maybe 32-35 psi. Bigger throttle will give a slight increase in throttle response but more air means your going to need more fuel</p></blockquote><p></p>
[QUOTE="Sn95289, post: 1424520, member: 22077"] You can look to get 20-25 hp right of the bat but if if you put good tune you can look closer to 30. Advance timing and add fuel pressure to maybe 32-35 psi. Bigger throttle will give a slight increase in throttle response but more air means your going to need more fuel [/QUOTE]
17 minutes ago
Today at 2:42 PM
Today at 1:48 PM
Latest: MasterDot
Today at 12:03 PM
New Member from Virginia
Latest: Daryl
Yesterday at 8:55 PM
yellow tang
Realistic gains
