Gentlemen, need to replace my vapor canister on 2002 GT. It's leaking smoke like crazy. Is this something I can do myself or is it a big undertaking? Will I need any special tools or equipment? Thanks in advance, Lonestar
Basic hand tools should do, take off passenger side fender, don't forget to take out inner fender bolts. It's two hoses and a clamp that holds it in place. It should only take 1-1.5 hours. Just a tip, put masking tape on the passenger side door and fender so it doesn't get scratched Sent from my SM-N900V using Tapatalk
The canister I believe is located next to the gas tank by the drivers rear tire. Looks like I would have to deal with the gas tank, plate and exhaust tip. Is there an easier way to get to the vapor canister? Lonestar
Pretty sure canister is up front in the fender. That's where they were when I permanently removed mine. This message courtesy of crapatalk!
I'd recommend also replacing the vaccum lines going to and from it at the same time. Mine were pretty brittle. I was chasing down a vaccum leak and replaced the tubing
