Michael Soldan
I put new headlights in my sn95 after buffing the old ones several times with not real great results. They did look better but I decided to replace them. There are several You tube videos showing how to do it , but I learned a whole lot that the videos don't show you. I learned to set my old headlight beside the new ones and count the number of threads on each mounting rod. By setting the new headlamps identical to the old ones I found they fit in and were aligned almost perfectly to the old ones , this makes adjusting the headlights easy if one assumes they were aligned before , so a few turns here and there and you have them dead on. Just a thought when you go to replace your headlights . Mike in Exeter Ontario
