Vettn71
Have a 96 GT, worked over 4.6 with a 0.20 over Cobra aluminum block. I have a C&L plenum, BBK 75mm throttle body, Competition Cams 268 cams, 10.5:1 compression (9cc dish), PI heads (with some pocket porting) and intake, three-angle valve job, stock exhaust manifolds and an AirRaid CAI. I know all this isn't necessary, but someone is bound to ask. I just had this thing tuned and it put down 298 to the rear wheels; not bad. My goal was 300, The tuner, Travis at GearHeads, said he pulled some timing because I had bad gas. I'm okay with that. As far as I see it I made my goal. Oh, yeah, this is a 5-speed car with 3:73s.
my question is about throttle bodies. I keep reading how the BBK is not so good, both in quality and performance, especially idle quality. I am having some issues getting it to idle down. Travis recommended dropping the idle speed using the idle adjusting screw, but when i get the idle lower than 1,000 rpms, it tends to die. The idle also hangs pretty bad. It will go to 2,000 when I pull up to a light, then 1500, then to its final idle. I've got it where it doesn't die on me, at least. I know hanging idle is one of the characteristics of the 4.6, but mine takes a loooooong time.
Would an an accufab throttle body help?
TIA
Jim
TIA
Jim
