Ticking noise ... help !!!
Scitec
Germany
Hey guys,
since yesterday I have this ticking noise in my enginebay. The engine is completely stock and has 40k miles on it. It's only if the car is warm and around 1800rpm. I really can't locate where it's coming from.
I changed my oil for about 3000 miles (but it's around 1 year old) and it's filled up. I also have new ignition wires and new spark plugs. First I thought it could be a bad lifter, or a chain timing problem, but should it not be if the engine is cold too? Or maybe can it be a bearing at the alternator?
Here's the video:
http://www.youtube.com/watch?v=WPtgnwzZ_H8&feature=youtu.be
check to make sure your spark plugs are all connected tight on both ends and look to see if your header bolts are coming out. Had to give mine a couple of turns 2 weeks ago to get rid of my clicking/exhaust leak.
spark plug could be backing out.
exhaust leak (header gasket).
fuel injector.
cam follower.
etc. etc.
get a screw driver and take a listen. let us know where its coming from :-D
lndabrkes01
