May 27, 2020 #1 Adam Vinnicombe Active Member Joined Jun 28, 2019 Messages 498 Reaction score 71 Hi all. Can anyone confirm what oil I should use in a Tremec T 3650 gearbox? what amount of oil is needed? also can I fill the box up by pour the oil in the big square hole the shifter bolts to? Like in the photo
May 27, 2020 #2 white95 Apex Junky Admin Joined Dec 30, 2007 Messages 21,798 Reaction score 11,646 Location Prairieville, LA Recommended Oil and Fill Capacity: TREMEC engineers have recommended Texaco-Havoline Dexron III/Mercon Non-Synthetic ATF. Read this: http://www.paladinmicro.com/documents/TSB-TrannyFluid-04-15-6.pdf and this: https://www.bullittarchive.com/1018.htm
May 27, 2020 #3 OP OP Adam Vinnicombe Active Member Joined Jun 28, 2019 Messages 498 Reaction score 71 Cheers mate
May 27, 2020 #4 white95 Apex Junky Admin Joined Dec 30, 2007 Messages 21,798 Reaction score 11,646 Location Prairieville, LA Anytime
Jun 4, 2020 #5 Wade_GT New Member Joined May 12, 2020 Messages 22 Reaction score 18 Location Los Angeles I’ve tried Redline Synthetic and valvoline ATF and remain most satisfied with factory full Mobil 1 ATF after switching back.
Jun 11, 2020 #6 Boostr1 Active Member Joined Apr 17, 2020 Messages 927 Reaction score 650 Location North Jersey I seen somebody use Mercon automatic fluid.
Jun 11, 2020 #7 RAU03MACH Legend Joined Apr 23, 2019 Messages 9,246 Reaction score 9,693 Location NEW MEXICO I am using Marcon Valvoline
Jun 11, 2020 #8 96blak54 Moderator Staff member Staff Joined Feb 21, 2011 Messages 15,616 Reaction score 6,519 Location Lawrenceburg Kentucky I had an eye open once after running store grade dex3 and switching to royal purple. Lesson learned?....dont use store grade!
Jun 11, 2020 #9 MustangChris Mythic Level Joined Aug 20, 2008 Messages 27,282 Reaction score 951 Location Aurora, CO yes you can pour the fluid directly into the shifter location. Tremec also makes their own fluids, if you want to go that route.
Jun 12, 2020 #10 OP OP Adam Vinnicombe Active Member Joined Jun 28, 2019 Messages 498 Reaction score 71 Cheers for the replies all
