Turbo 5.0s
Suspect
ATL
come in and talk about ur cars.. list ur combos. list ur hp #s. how often do u drive it. whats problems do u have with the car.
Magic
Some time zone
A buddy of mine (also a customer at the shop I worked at)
94GT, R302 block based 331 stroker, VIctorJR heads, TFS Track Heat intake, F-303 cam, HP Stage 3 76mm single turbo, tremec tko600, spec stage 3 clutch, complete fuel system (60lb injectors, twin extrnal 255lph walbros, rails, etc).....car made over 600rwhp...custom tuned with a Tweecer RT by the owner (idles like a Mercedes and goes like a raped ape)
The car driven everywhere and anywhere and whenever possible....hes gone to the US and back...various number of trips to his hometown and back (300miles each way), various high speed runs with Porsches and built C5 Vettes....runs like a swiss watch....
Only major things hes had an issue with is, hes gone thru a cpl clutch cables (they fray due to the heat, but it seems to be solved now), and it used to have a SPEC Stage 4 in it before, and after getting excessivly hot, the disc would "fuse" itself to the flywheel, has a happened twice, so as of last week a SPEC Stage 3 lives in there....
scott5
myrtle beach, sc
mine is not done yet but i can put up my setup
Dart block bored to 331
331 stroker kit
Holley systemmax 2 intake (ported)
Victor Jr heads (ported)
Complete aeromotive fuel system
A custom comp cam and valve train
Twin 66 mm turbos...
This setup would make 1krwhp but am staring it off at 550 rwhp at LOW boost.
