turbo kit for 2v ???
Green Goblin
i have an 01 gt with a vortech on 12lbs. lets just say i have all the supporting mods for about 800 hp. looking for a single turbo kit for a 2v. post all links or company's you know of that make kits for a 2v. thanks.
Dalamar
SLC, UT
I have the hellion kit, and am very impressed with their quality and quick delivery.
their pipes are all SS and made by Bassani, they know how to make it all work together!
I added some other pieces to make it purdy under the hood, but you can see most of it.
the coolant crossover is also part of their kit.
Here's a few pics:
1996mustangGT
justinschmidt1 said:
1996mustangGT said:
Check out www.spyderturbosystems.com
Great bunch of guys. If I had the money I would be going to them.
I looked at them before...I wish I would have went turbo!
They are super cool guys, and their kit can be had for under 5G's. A lot of the kit is "modular" if you will, in that a lot of it is optional. IE the K member kit, coilovers.
I think I'll be happy with the SVO Charger :)
LAFENATU
B&G Turbo Kits are supposed to be a very reasonable kit that make great power.
http://bgturbokits.com/store
B&G STAGE 3 96-04 4.6 2v
Starting at: $3,500
We have finialy released our 96-04 B&G Kit.
The kit comes standard with a MP-t 67
Requires slight triming of the inner bumper for clearance of the huge intercooler. Keeps all accessories. We have put great effort into making a great fitting kit that only needs to be built once, it is guarnteed to fit your mustang without you having to rebuild it just to get it to work. As long as your mustangs frame rails are where they supposed to be, I guarntee this kit to fit. No more cutting up your whole inner fenderwell just to get a ill fitting kit to work.
!!!!!!!!!!PLEASE NOTE!!!!!!!!!!!!
You must run a aftermarket k member with coil overs. Test fitted with d&d and Qa1 k members only.
You must move the driverside coil pack on 96-98 4.6 cars.
You must remove the standard over flow tank.
Will Fit up to a pt-78. 96-04 4.6 KIT
Hotside comes with:
1. Y pipe steel crossover, with stainless flex joint, machined vband flanges.
2. 3" Turbo mount. 16 guage mild p>
3. Aluminized steel mandrel bent 3.5 downpipe.
4. Aluminized steel mandrel bent 3.5 lower downpipe into 2- 2.5 ball ends with flanges for cat back hookup.
5. B&G 38mm street gate, upgrades available
6. GT4088 standard, upgrades/downgrades available
7. All v-band clamps needed for install
Coldside comes with:
1. 3" coldside from turbo to intercooler
2. 1200 hp rated intercooler
3. 3.5" coldside to mass air meter. Set up with bolt on meter flange
4. All silicone couplers with t-bolt clamps, needed for install.
5. B&G/TC 50 mm B.O.V
OIL LINE KIT INCLUDES
Full oil line kit, all -an fittings Braided lines.
Comes with:
1. Turbo drain flange
2. Oil Pan Bung
3. -10 Oil drain line (Braided stainless steel with -an fittings on both ends.)
4. -4 Oil pressure line (Braided stainless steel with -an fittings on both ends.)
5. Turbo oil pressure inlet fitting.
6. Block fitting.
MISC ITEMS NEEDED FOR INSTALL BUT NOT INCLUDED:
1. Upper hard line and fill neck.
2. Overflow tank
Muscle Mustangs & Fast Fords just installed a B&G Turbo Kit on their daily driven Fox Coupe. On 10 PSI the stock fox made 420/465
They bought the base kit for $2700.00
Here are pics of the 2V single kit and twin kit.
G
Green Goblin
built bottom end. ford iron block, cobra pump and pickup, kellogg cobra crank, scat h beam rods, mahle coated lightweight pistons, arp everything bolts and studs. been beating on it for 3 years in new orleans heat on 12 lbs. just want to go 70mm or so turbo. car is getting coil overs this week. time to sell the eibach pro kits. tubular kmember if i can sell some wheels. thanks guys.
