supermech21
- Joined
- Sep 8, 2007
- Messages
- 20
- Reaction score
- 0
Ok, getting ready to move on turbo 95 cobra. Right now the important parts on it are : 67mm turbo, the full turbo kit(headers, IC, pipes), AFR aluminum heads (i wish i knew the size i want to guess 195cc flow), Tremec tko 500(the strongest 5 speed they made), Fuel system. Thats the main stuff. Notice how i didnt say anything about the bottem end cause its near stock (rebuilt with under 1000 miles, i believe its a 306 but with a stock bock). The tuner (brandon Haywood,NC) he says he can get 600 but that seems a little excessive wit the bottem end in it now.
Future plans: Dartblock, 331 forged bottem end, AEM EMS, Water/meth injection. My only questions are who is running a 331 with a big turbo, and what is your compresion? Can someone provide a link because i dont want to run above 8.5:1.
Questions:
If you have a 67mm or larger turbo whats your bottem end like? Comression? Block? How high do you rev?
What are you guys running for a tuning system. The AEM unit is hands down the best on the market and this turbo should make power to 6700-7300 rpm's.
Whos running Water injection? Where did you get your kit? Just running a boost source for actvation or off the TPS as well?
What size cam should i be looking at? He said it has a "turbo cam" but hes just looking at a powerband of 6k, i want to take the turbo to ts limit and im thinking 6800(thanks to the EMS) would be a great shift point. Can you guys recomed a degree'ed cam for me?
This car will see mixed racing track/highway, but most of my fun is done on the highway. I want to make this as safe as possible to run on the street at high speeds, what suspension wise can i do to keep the car squated down and staying sraight? I have no clue as to whats on it now for suspension other than Eibach springs(has 10.5" cobra R's alsoif that helps).
Any other words of wisdom? I want 700 hsp (on a 110/93 mix + meth). I want a block that i can grow with, a 72 or 76mm turbo may b in my future but i dont know.
Questions:
