Two top bolts on the transmission
martinbaca18
What is the easiest way to take off the two top bolts on the transmission? I have a 3650 tranny.
DeepList
Administrator
Auburn, IN
You can try a flex socket and a long extension, or a combinations of different length extensions. What I do is loosen motor mounts and rear transmission support. This allows you to lower the transmission down a bit and get a little better accessibility to those bolts. Make sure everything is supported!
martinbaca18
martinbaca18
Ok would o need a cheater bar for those two bolts? Or do they unscrew pretty easy?
DeepList
Administrator
Auburn, IN
I've never had any problems getting them loose, but if they seem tight, I'd spray some PB blaster and let them set for a while. Use a 6 point socket.
D3VST8R96GT
Marble Fall, AZ
I jacked the tail of the transmission up which tilted the motor forward enough to get my fat ass arm behind the motor from the top.... 13mm racheting wrench
1997GT4.6
Couldn't you remove the rear trans cross member and use a jack to lower it so the 2 bolts are at an angle and can be reached simply using a long extension?
This is also what I did when I pulled my tranny from a junkyard with basic hand tools.
1997GT4.6
^ I wonder if there is enough room for that on a dohc. Looks really tight back there (hehe). But that's a great idea.
gtwo
Easiest way hands down is to pull the intake. Then it's any ratchet and socket you want. I can pull an intake in less than 30 minutes and the gaskets are reusable.
This is how I do it on Mustangs and F-series trucks. Pulling the intake is really easy and gives you a whole lot of room to work from the top.
T's Convertible
