Unknown engine setup, svo 4v?
Slow_n_steady
Hey guys so i stumbled upon a 96 gt chasis that the vin all says its a stock gt, it has a 4.6 ecu (ddx3) however the motor is a dohc setup of which im not sure, ive only been able to find one image of the intake and it said it was an svo intake, it also has what i found to be svo side pipes, ive found some info for part numbers to check but havent been able to check the heads numbers yet, can anyone help me identify what is going on with this.20220825_114047.jpg20220825_114021.jpg20220826_115148.jpg20220825_113822.jpg 20220826_115247.jpg
Snorky
As for performance goes, that kind of engine might get you 250-270ish whp from the factory. They're not bad. But the c heads are way better. Unless you are revving the thing out to 8-9000 rpm... then the B heads are chamipions. This was demonstrated by Mihovitz time and time again.
Can do some rods, pistons, better timing equipment. some cams/springs and it would be a great platform to run ALL of the boost into.
Cwacaser
