Vids from this weekend
eric
car started making more boost at the end of the night, i was launching at 3k with the t brake, i think i need to start checking the stall again. MY 60'd ranged from 1.8's to high 1.7's....
1. 12.1 @ 111
2. 12.1 @ 113
3. 12.1 @ 117
4. 11.92 @ 119
5. 11.83 @ 120
6. 11.83 @ 120
http://www.youtube.com/watch?v=TfPzXIuMkZE
http://www.youtube.com/watch?v=IRS_kfvoVQA&feature=channel
http://www.youtube.com/watch?v=LHTGvStIMPU&feature=channel
http://www.youtube.com/watch?v=FFFewkEPQVo&feature=player_embedded
i
E
eric
built SB, heads,cams, v-1 making 10#'s of boost, swapped auto 4600 stall, PA TB valve body. made 390 rwhp...
JDwhite98gt
Whats the suspension/tire/rear setup? Also, where are you at as far as sealevel and conditions of the day and the track? Nive MPH but thought that maybe you should be running a little faster?
E
eric
26" et streets, UPR solid upper and lowers, anti roll bar, i have a 3.73 in the rear. Im going to be swapping to 4.10 soon, i have another 700-1k rpm to go before red line at the traps. The car should def be in the low 11's with that MPH, my stall was set up for about 600 hp on the motor but the s trim hasn't been kicking out as much boost as i anticipated. The track's elevation is at 1100 feet and the DA during the day was around 3400, and once it cooled down it went to 2500....
duff daddy
good driving, With the Hp and depending on weight of the car I was going to say you should be a little faster then that but its all relative. I will take a 11.6 all day ever day over a 11.3 then a 11.8 then a 12.2 and a 11.4. Consistency how you and the car perform together are more important then a top ET car every 5th run or so ya know?
I would like to see where you car is at with a 28" tire and the same set for rear gear. FIND SOME!!!
E
eric
im considering a 28" tire with the 4.10 once the power picks up, i have been debatign weather to just do a t trim conversion or get a over drive pulley to max the blower out, i know if get either this thing should be a whole nother animal...lol
E
eric
i still have another 700 to 1K before red line...so the 4.10's are def going to help
duff daddy
Yea do that I ran a 12.67 NA last year and was shifting to 4th at the 1,000 marker..... yeaaaaa tell me about wrong gear/tire size haha
Ninety8stang
Duh405
haha when i was running the stock gears in my 98 i was making it to the top of 3rd before rolling through the traps.
