What cam should I get?
CompOrangeSN95
North Jersey
Hey guys as some of you may know I am doing a carb setup on the new 302 that I got, I plan on using a weiand x-celerator intake, holly 700cfm carb, and cast iron explorer heads, my problem is I really don't know much about cams, I'm just looking for some advise on how to pick the right cam for my set-up, keep in mind that is is a track only car. thanks in advanced for the help!
badass96gt
My 84 had a similar combo and the Trick Flow stage 1 worked very well in it, except That 700 carb might be alittle big. I was running a BG 650 speed demon and it worked very well for that combo.
CompOrangeSN95
CompOrangeSN95
North Jersey
cool I will look into it, I think you're right about the 700 being to big, but I might be able to get away with it if I port the heads. do you remember how much power it made?
