what HID kit should i buy??? ordering today or tomorrow
98GTnSC
ok guys im wanting to order the DDM Tuning HID slim ballast kit. should i get the hi/low beam or just the low beam headlights and why should i get that one? thanks. but the kit WILL be the DDM Tuning kit
I got the high/low kit but there's not much difference in the way out output. It wasn't much more so i figured wtf and it helps keep the car legal with high/low beam.
98GTnSC
alright well thats enough for me. and does the hi/lo beam kit contain bulbs for the hi and lo beams? says the full kit contains 2 bulbs but i think thats talking about just the low beam only kit. ima go ahead and get the hi/lo beam kit. cant wait any longer!
wnracing
Hi/Low HID's have two capsules, one for each side just like a standard halogen setup.
-Removed because I was mis-informed, sorry.- :BangHead:
Oh yeah, if you're going to do your headlights, don't forget to get a single beam kit for your fog lights too if you have them. (Personal opinion.)
98GTnSC
yeah im wanting to do my fogs too. would i order a separate low beam HID kit and install it the same as i do the headlights? i know the headlights are 9007. are the fogs the same? thanks for any help.
wnracing
The fog lights should be a single beam 899 Kit. I think the Cobra's are the same or use an 893 bulb, they would all have the same base.
Looks like DDM doesn't specifically sell the 899 or 839, but the 880 kit should be the same.
Win
Kennesaw, Ga
The headlights do 6k. If you go 55watt they will be more white then blue and if you go 35watt they will be have more blue in them. With the Fogs all you have to do is get a 800 Series bulb kit. All 800 series kits work. I have the VVME 6k kit and i love it :)
Had to add Abbreviations sorry
DDM FTW...I have the single beam 8k in my headlights, just because I've had a million problems with my hi/lo VVME kit, so when I switched to DDM I went with the single beam and have had zero problems.
wnracing said:
Hi/Low HID's have two capsules, one for each side just like a standard halogen setup. Each capsule has two champers, one with the low beam xenon gas and if you want the Hi-beam, it ignites the second chamber of xenon gas in the other chamber.. Complicated, but simple at the same time.
this is wrong. there is not a separate chamber for high beams, it simply moves the bulb to one side to reflect off a different part of the headlight housing.
As for the fog lights go, I have the 880 kit.
wnracing
Hmm, Interesting. I can't find where I had read that at one point, but I suppose that I was mis-informed. Thanks for the info.
This actually seems to be a pretty good explanation of different HID's and how they work.
http://zh-cn.facebook.com/topic.php?uid=199366289244&topic=13021
Dws 95 mustang GT
